Power Supply
1 Answer 1 Score |
The monitor has display problems |
1 Answer 0 Score |
How to fix 1907FPc 19" LCD Monitor feet from tucking? |
1 Answer 2 Score |
Would it work if I swapped a monitor motherboard with a tv panel |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Technical Specifications
Brightness: 300 Lumens
Contrast ratio: 700:1
Display Size: 19.0 inches
Refresh rate: 60.0 Hz
Resolution: 1280 x 1024 pixels
Response time: 8.0 ms
